12 years ago --- Quote Start --- It is possible to import a pinmapping right? --- Quote End --- Sure, but there still has to be a one-to-one mapping between the pin names in your top-level HDL entity and your pin mapping script or spreadsheet. If you look at the tutorial source, you will see that correspondence, i.e., a top-level HDL file and a Tcl script with pin constraints, where those constraints use the same name as the top-level HDL. If your top-level HDL is generated by Qsys, then the top-level pin names change depending on how you name the components in the system. --- Quote Start --- Than I would think the problem with not knowing how to put the signals together would be over, or am I thinking about this a little too easy? Let's say at least the inputs and outputs from the top-level are always the same, but only the signals vary with different components. I always have a component of type A, this component also always has the same in and outputs for every different component (so it only differs in architecture). And I also always have a component of type B, same inputs and outputs for every different component again. Now I always want to connect a (yet undefined) component of type C, to a component of type A. And a (yet undefined) component of type D also connects to type A and B. So we've got: C<>A<>D<>B Always Is it than still not possible to say: ok since we have type A we need to connect it with type C and we need to do it this way: input Ax <= output Cx, input Ay <= output Cy --- Quote End --- This problem can be solved using VHDL configurations. In VHDL a 'component' definition tells the compiler what pins a component has. Using a configuration you can map an entity to a component. In your code, you can write the code to include known components A and B, and connect them to 'component' definitions for C and D. Then you use a configuration to map C and D to their implementations. I posted a VHDL configurations example in this thread: http://www.alteraforum.com/forum/showthread.php?t=30414&page=2 Take a look at VHDL configurations and let me know if they meet your requirements. If they don't, we can discuss using generate statements, generics, and Tcl. Cheers, Dave
