10 years agoGenerate Real FFT IP
Hi, I would like to generate a real 64 point FFT. i.e. it takes 64 real input and generates 32 complex output bins. As per myy initial analysis, Altera MEgacore generates only complex...
10 years agoYeah sure.. but the multiplications will be complex even though the input is real...so its an easy but inefficient way of implementation
So i found this paper http://www.ti.com/lit/an/spra291/spra291.pdf This paper explains how the symmetry of the twiddle factors can be exploited to implement 64point real FFT using 32 point complex FFT (by making odd numbered of input as real and even numbered input as complex)
