dj-park
3 years agoGenerate only partial bitstream not the full bitstream
In Partial Reconfiguration flow, I've noticed that when I compile
a Persona Implementation, it generates both the full bitstream(.sof) and
partial bitstreams for all PR partitions(.pmsf and .rbf...
- 3 years ago
The .sof files for each implementation revision allow you to test your design with that persona in place without having to perform a PR first. If you don't use them, just ignore or trash them.
Once you have a .pmsf file for a partition, use Convert Programming Files to create a .rbf for it. Your workaround is saying that partition_2 is a SUPR (static update PR) region. Normally a .rbf file is created for a SUPR region even though you can't use that .rbf to PR a SUPR region during runtime (why it's call static). I guess I'm not sure what your goal is with (2).
sstrell
3 years agoSo .pmsf only generated for A10 and C10: https://www.intel.com/content/www/us/en/docs/programmable/683834/22-2/step-9-program-the-fpga-device.html
