Generate only partial bitstream not the full bitstream
- 3 years ago
The .sof files for each implementation revision allow you to test your design with that persona in place without having to perform a PR first. If you don't use them, just ignore or trash them.
Once you have a .pmsf file for a partition, use Convert Programming Files to create a .rbf for it. Your workaround is saying that partition_2 is a SUPR (static update PR) region. Normally a .rbf file is created for a SUPR region even though you can't use that .rbf to PR a SUPR region during runtime (why it's call static). I guess I'm not sure what your goal is with (2).
Thanks for the prompt reply.
The objective of (1) and (2) are both to reduce the bit generation time.
What I am trying to do with (1) is that
if I can generate only .rbf file for partition_1, for instance,
then the bit generation time is shorter than when I generate both .sof file and .rbf file for partition_1.
I wonder if there exists any option for this.
Regarding my workaround...
below is the Design Partitions Window, and I set the "RBF Generation" as "No" for leaf_2~leaf_9 so that I don't generate
.rbf files for them. They are NOT set as SUPR. I checked the SUPR tutorial in here(https://github.com/intel/fpga-partial-reconfig/tree/master/tutorials/agilex_pcie_devkit_blinking_led_supr), and
if they are set as SUPR partition, they are not colored yellow I guess.
