Generate only partial bitstream not the full bitstream
- 3 years ago
The .sof files for each implementation revision allow you to test your design with that persona in place without having to perform a PR first. If you don't use them, just ignore or trash them.
Once you have a .pmsf file for a partition, use Convert Programming Files to create a .rbf for it. Your workaround is saying that partition_2 is a SUPR (static update PR) region. Normally a .rbf file is created for a SUPR region even though you can't use that .rbf to PR a SUPR region during runtime (why it's call static). I guess I'm not sure what your goal is with (2).
2. is resolved by having
set_instance_assignment -name RBF_FILE_GENERATION_FOR_SUPR OFF -to pr_partition_2
in .qsf file. I am not sure why the it is RBF_FILE_GENERATION_FOR_"SUPR", but it seems to exclude
pr_partition_2 when generating partial bitstreams.
Quartus is still generating the full bitstream(*.sof), so 1. is not resolved yet.
