10 years agogenerate clock after a specific number
hi! I started to learn VHDL,so be patient :) also my english is poor :cool: but I try to explain my problem: I try to emulate a code for generate (and delay it by a precise integer) the clo...
10 years agomy code is:
entity test_out is
generic (period: time :=100ps;
halfperiod: time := 50ps);
port ( rit: in integer range 0 to 255; --delay for start clock
localCLK: inout std_logic
end test_out;
architecture beha of test_out is
signal clock: std_logic; --used to recycle the process
signal uscita: integer range 0 to 255:=0;
begin
clock<='0','1' after halfperiod;
process(clock)
begin
if (clock='1')then
clock<= '0' after halfperiod;
else clock <='1' after halfperiod;
end if;
case (rit) is
when 0 => uscita<=0;
when 1 to 10 => uscita<=1 after 1ps;
when 11 to 20 => uscita<=2 after 10ps;
when 21 to 30 => uscita<=3 after 20ps;
when 31 to 40 => uscita<=4 after 30ps;
when 41 to 50 => uscita<=5 after 40ps;
when 51 to 60 => uscita<=6 after 50ps;
when 61 to 255 => uscita<=7 after 60ps;
end case;
case(uscita) is
when 0 to 255=> localCLK <='1', '0' after halfperiod;
end case;
end process;
end architecture; But with this code I can not emulate a clock signal with a duty cycle of 50% and also does not initialize after a time I'll try again, while some idea? :D
