10 years agoGenerate a pulse by using a counter/timer
Hello, I just started with FPGAs and thus I am trying to improve my VHDL skills. Recently I am building a design that generates a pulse which is meant to start a ADC conversion. My idea is to use ...
10 years agoThis is the culprit code:
-- gererate start pulse --
process (control_register(2), counter_value)
begin
if (rising_edge(control_register(2))) then
counter_reset <= '0';
counter_clock_enable <= '1';
start <= '1';
elsif (counter_value = x"0000ffff") then
start <= '0';
counter_clock_enable <= '0';
counter_reset <= '1';
control_register(2) <= '0';
end if;
end process;
This is not good code, so I have no idea what the synthesisor made of it. Did you look at the RTL and technology diagram? You should clock this with "clock", and make an edge detector circuit with control_register(2) -
process(clock)
begin
if rising_edge(clk) then
control_register2_r <= control_register(2);
if control_register2_r = '0' and control_register(2) = '1' then -- you have a rising_ege on the signal
Do you have a testbench to test this code in the simualtor? And as you're trying to improve your VHDL skills - stop using std_logic_arith and std_logic_unsigned. They are non-standard VHDL libraries. Use numeric_std instead.
