16 years ago --- Quote Start --- Just check synthesis report and warning messages. but nothing sticks out since the part of the removed or stuck to GND and VCC is expected. I'll keep looking, but thanks for the suggestion. --- Quote End --- Hi Petelu, do you have a problem with "x" in your gatelevel simulation? Maybe you can try a longer reset sequence, in order to get rid of all the "x". Look carefully how the synthesis tool has the reset implemented. Are all registers connected to the reset signal ? Kind regards Gerd
