Gated clock conversion fails due to memory
- 5 years ago
Thanks for pointing out these attributes, but unfortunately they do not seem to have an impact on clock gate conversion (CGC)
But I've found a solution: instead of using a single write enable (WE) for a 13 bit data word, I've used a WE for each 8 bit data slice. This seems to help the compiler to find a RAM block which is suitable for CGC
Instead of:
wire s_wen; assign s_wen = (~CEN) ? WEN : 1'b1;Changed to:
wire [1:0] s_wen; assign s_wen = {2 {(~CEN) ? WEN : 1'b1}};See also attached files.
You may use below two settings in the QSF file.
RAMSTYLE_ATTRIBUTE: https://www.intel.com/content/www/us/en/programmable/documentation/eca1490998903550.html#analysissynthesisassignmentsramstyleattribute
BLOCK_RAM_TO_MLAB_CELL_CONVERSION: https://www.intel.com/content/www/us/en/programmable/documentation/eca1490998903550.html#fitterassignmentsblockramtomlabcellconversion
Instead of:
Changed to:
