Alexander_Kobler
5 years agoGated clock conversion fails due to memory
Hello Intel community,
We use "set_global_assignment -name SYNTH_GATED_CLOCK_CONVERSION ON" for our prototyping system, which contains several memories (RAM, ROM). Up to now, this worked as expecte...
- 5 years ago
Thanks for pointing out these attributes, but unfortunately they do not seem to have an impact on clock gate conversion (CGC)
But I've found a solution: instead of using a single write enable (WE) for a 13 bit data word, I've used a WE for each 8 bit data slice. This seems to help the compiler to find a RAM block which is suitable for CGC
Instead of:
wire s_wen; assign s_wen = (~CEN) ? WEN : 1'b1;Changed to:
wire [1:0] s_wen; assign s_wen = {2 {(~CEN) ? WEN : 1'b1}};See also attached files.
sstrell
5 years agoThe simplest (and best) solution would be to not gate your clocks. Manually put that logic on local enables or on the enable of a clock control block instead.
