15 years agoHi,
I hope you realise that changing Fs for a given filter will change the response proportionally. If your filter is fixed for a response at Fs of 500Ksps to produce a notch at 100Hz, then that notch point will move to 100 *125/500 = 25Hz if Fs is made 125Ksps. How do you know your input is at a given freq. If you generate from LUT then the freq will depend on Fs at LUT
