15 years agoOkay, For the timing issue:
Type : Slow Model Clock Setup: Slack : -7.425 ns Required Time : 40.00 MHz ( period = 25.000 ns ) Actual Time : 30.84 MHz ( period = 32.425 ns ) From : "...input path to input of the filter" To : "...output path to output of the filter" From Clock : path to 40MHZ clock from PLL To Clock : path to 40MHZ clock from PLL Failed Paths: 7874 40MHZ is input clock to a different module to generate 500 KHZ enable or ready signal. I use this ready or enable signal which is 500KHZ as clock for my filter. i dont use 40MHZ directly even once. I added this path in assignment editor, with assignment name "clock enable multicycle" and a value = 2. But error is still present. Perhaps, i should have assigned "Multicycle" and a value of 2. I am compiling the project and will update you soon. Please suggest, how to proceed.
