15 years agoI entered Matlab:
a = [1.000000000000000, -1.999747125328010, 0.999748704265674]; >> b b = [ 0.999886916919553, -1.999747125328010, 0.999861787346121]; >> fvtool(b,a) or use freqz(b,a) I get a notch filter. its notch occurs at .001 of Fs 100000 = 100 Hz and this matches your description. However the attenuation is -.008db = .9991 As to your hex values it gives a completely different filter if I convert it on the basis of 2's complement...you need to check that
