16 years ago --- Quote Start --- Aaaaaaaaaah, you can run "Compile Design"... Why the same results wouldn't be achievable running them one by one is beyond me..................................................................................... --- Quote End --- Hi, you need a full compile for the gatelevel simulation, because the simulation includes the timing. The timing information is available after the design is P&R und the timing is analyzed. Kind regards GPK
