Altera_ForumHonored Contributor12 years agoFunction to_unsigned returns only zeros Hello, I'm programming a FIR Filter in VHDL and I want to insert stuck on errors in the taps.. so, I did this: SIGNAL tap0, tap1, tap2, tap3 : INTEGER :=0 ; SIGNAL error : INTEGER...Show More
Altera_ForumHonored Contributor12 years agoinstead of posting just a snippet, which is riddled with errors, why not post the real code?
Recent DiscussionsFree Licence for Max+PlusIIMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected report
