9 years agoFull compulation for large IO pins
Hi I would like to perform full compilation for component (not the Top Level) that has large IO pins. Im looking at over thousands bits in output bits. But I need to know the total LEs and Fmax...
9 years agoWithout seeing the code, I cannot really say alot.
But long compiliation times for idividual modules (eg >30 mins) is likely a problem in the code and the easiest way to kill it is to have a large ram that gets inferred as registers instead of Ram blocks because the behaviour is incorrect. Can you post your code?
