9 years agoFull compulation for large IO pins
Hi I would like to perform full compilation for component (not the Top Level) that has large IO pins. Im looking at over thousands bits in output bits. But I need to know the total LEs and Fmax...
9 years ago --- Quote Start --- Hi I would like to perform full compilation for component (not the Top Level) that has large IO pins. Im looking at over thousands bits in output bits. But I need to know the total LEs and Fmax of the that particular component. Any ways to do so? apparently there would not be any device that can provides such large pins. Thanks --- Quote End --- To compile a design, you have to select a particular architecture (ie, CycloneV, for example) and a specific device and package within that architecture. You can't compile for a device that does not physically exist. Can you explain further what you are attempting to do?
