8 years agoFSM: a state gets latched
i am running a state machine. Simulation shows everything is OK. Real life implementation is showing otherwise. I keep track of the states using on board LEDS showing the current FSM state. The problem is that at a certain point (couldn't figure out if there is a specific sequence except that its not from the WAIT STATE), the FSM transfer to the INIT STATE and gets stuck there until i do a POWER reset, which is weird by itself because there is no such transition possible, as i made sure that the reset_L signal is not LOW. and gets stuck at that state, even though that even if such a transfer should happen, an immediate transfer to WAIT state should happen but doesn't. I cant find the reason and the solution, please help... THE CODE IS ATTACHED
