FPGA Programming by Command Line
I have finished project implemented in Standard Quartus18.1 for MAX10 device. The final bitstream is encrypted. Currently, I use Quartus Programmer GUI, to program each device. However, I would like to implement command line tool which program fpga automatically.
In Programmer GUI, I am merging ekp together with pof file (by right clicking on the pof file and selecting add ekp file). How can I do this by command line?
Sulaiman
- Sulaiman
I understand from you, we can only program encrypted pof using GUI programmer!
Sulaiman
- NurAiman_M_Intel
Per my understanding, you would like to use command line to program FPGA? If yes, kindly refer to Intel MAX 10 configuration user guide below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf
Aiman
- Sulaiman
Yes I would like to use command line to program FPGA but with encrypted pof.
I can not find it in pdf file. Can you determine the page number?
Sulaiman- ak6dn
I use the 'make' system to run a command line compilation of a design using Quartus.
Here is my Makefile:
DESIGN=DE0_PDP8 all:: generate report generate:: $(QUARTUS_BIN)/quartus_map $(DESIGN) --write_settings_files=off $(QUARTUS_BIN)/quartus_fit $(DESIGN) --write_settings_files=off --seed=1 $(QUARTUS_BIN)/quartus_asm $(DESIGN) --write_settings_files=off $(QUARTUS_BIN)/quartus_sta $(DESIGN) $(QUARTUS_BIN)/quartus_sta -t generate_timing.tcl $(DESIGN) 10 $(QUARTUS_BIN)/quartus_eda $(DESIGN) --write_settings_files=off -c $(DESIGN) $(QUARTUS_BIN)/quartus_cpf -c $(DESIGN).cof report:: @-echo ' ' -egrep --color -i '\([0-9]+ violated\)' TQ_*.rpt @-echo ' ' -egrep -vi '^this panel reports' TQ_fmax_summary.rpt @-echo ' ' clean:: -rm -f $(DESIGN).*.rpt $(DESIGN).*.summary $(DESIGN).*.smsg $(DESIGN).map -rm -f $(DESIGN)_assignment_defaults.qdf TQ_*.rpt PLL*.txt meminit.txt -rm -f $(DESIGN).done $(DESIGN).map $(DESIGN).pof $(DESIGN).sof $(DESIGN).jic -rm -f $(DESIGN).pin $(DESIGN).jdi $(DESIGN).qws $(DESIGN).*.ddb $(DESIGN).sld -rm -rf db incremental_db simulation # the end
To setup the Quartus environment (I use multiple versions, this sets up 16.0) I first run this shell script:#!/bin/bash # export QUARTUS_BASE=/cygdrive/C/Tools/Altera/16.0 export QUARTUS_ROOTDIR=${QUARTUS_BASE}/quartus if [ -e ${QUARTUS_BASE}/quartus/bin64 ] ; then export QUARTUS_BIN=${QUARTUS_BASE}/quartus/bin64 else export QUARTUS_BIN=${QUARTUS_BASE}/quartus/bin fi export QSYS_ROOTDIR=${QUARTUS_BASE}/quartus/sopc_builder/bin export SOPC_KIT_NIOS2=${QUARTUS_BASE}/nios2eds # echo QUARTUS_BASE=${QUARTUS_BASE} echo QUARTUS_ROOTDIR=${QUARTUS_ROOTDIR} echo QUARTUS_BIN=${QUARTUS_BIN} echo QSYS_ROOTDIR=${QSYS_ROOTDIR} echo SOPC_KIT_NIOS2=${SOPC_KIT_NIOS2} # # the end
Then in the design directory I just type 'make' and wait for it to finish. No GUI needed. I run under CYGWIN unix environment on Win10 64b.
- Sulaiman
I am using the following command to program FPGA:
quartus_pgm -m JTAG -o p;design.pof
When we want to program encrypted pof, we have 2 files(.ekp, .pof). We can program them together or separately. These methods are found in "Intel® MAX® 10 FPGA Configuration User Guide" document at page 51 but by GUI.
Can I do one of these methods by quartus_pgm commands.
Sulaiman
- NurAiman_M_Intel
Apologize for the delay in response as I did not received the notification.
Have you try the method suggested by our friend below:
Re: Re:FPGA Programming by Command LineMessage Body I use the 'make' system to run a command line compilation of a design using Quartus.
Then in the design directory I just type 'make' and wait for it to finish. No GUI needed. I run under CYGWIN unix environment on Win10 64b. Apr 24, 2021 5:34:22 PMPost Time Let me know if it is succesful or not.
Aiman
- Sulaiman
I didn't do the method from our friend. I think this method for generating the programming files.
My question is explained below:
Can I do one of these methods by quartus_pgm commands or other command.
Sulaiman
- NurAiman_M_Intel
You can use quartus_pgm command to program pofbut not ekp. Please see below link:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/tclscriptrefmnl.pdf (page 76-79)
Aiman
- NurAiman_M_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
