Sulaiman
5 years agoFPGA Programming by Command Line
I have finished project implemented in Standard Quartus18.1 for MAX10 device. The final bitstream is encrypted. Currently, I use Quartus Programmer GUI, to program each device. However, I woul...
Sulaiman
5 years agoHi,
Yes I would like to use command line to program FPGA but with encrypted pof.
I can not find it in pdf file. Can you determine the page number?
Sulaiman
Sulaiman
ak6dn
5 years agoI use the 'make' system to run a command line compilation of a design using Quartus.
Here is my Makefile:
DESIGN=DE0_PDP8 all:: generate report generate:: $(QUARTUS_BIN)/quartus_map $(DESIGN) --write_settings_files=off $(QUARTUS_BIN)/quartus_fit $(DESIGN) --write_settings_files=off --seed=1 $(QUARTUS_BIN)/quartus_asm $(DESIGN) --write_settings_files=off $(QUARTUS_BIN)/quartus_sta $(DESIGN) $(QUARTUS_BIN)/quartus_sta -t generate_timing.tcl $(DESIGN) 10 $(QUARTUS_BIN)/quartus_eda $(DESIGN) --write_settings_files=off -c $(DESIGN) $(QUARTUS_BIN)/quartus_cpf -c $(DESIGN).cof report:: @-echo ' ' -egrep --color -i '\([0-9]+ violated\)' TQ_*.rpt @-echo ' ' -egrep -vi '^this panel reports' TQ_fmax_summary.rpt @-echo ' ' clean:: -rm -f $(DESIGN).*.rpt $(DESIGN).*.summary $(DESIGN).*.smsg $(DESIGN).map -rm -f $(DESIGN)_assignment_defaults.qdf TQ_*.rpt PLL*.txt meminit.txt -rm -f $(DESIGN).done $(DESIGN).map $(DESIGN).pof $(DESIGN).sof $(DESIGN).jic -rm -f $(DESIGN).pin $(DESIGN).jdi $(DESIGN).qws $(DESIGN).*.ddb $(DESIGN).sld -rm -rf db incremental_db simulation # the end
To setup the Quartus environment (I use multiple versions, this sets up 16.0) I first run this shell script:
#!/bin/bash # export QUARTUS_BASE=/cygdrive/C/Tools/Altera/16.0 export QUARTUS_ROOTDIR=${QUARTUS_BASE}/quartus if [ -e ${QUARTUS_BASE}/quartus/bin64 ] ; then export QUARTUS_BIN=${QUARTUS_BASE}/quartus/bin64 else export QUARTUS_BIN=${QUARTUS_BASE}/quartus/bin fi export QSYS_ROOTDIR=${QUARTUS_BASE}/quartus/sopc_builder/bin export SOPC_KIT_NIOS2=${QUARTUS_BASE}/nios2eds # echo QUARTUS_BASE=${QUARTUS_BASE} echo QUARTUS_ROOTDIR=${QUARTUS_ROOTDIR} echo QUARTUS_BIN=${QUARTUS_BIN} echo QSYS_ROOTDIR=${QSYS_ROOTDIR} echo SOPC_KIT_NIOS2=${SOPC_KIT_NIOS2} # # the end
Then in the design directory I just type 'make' and wait for it to finish. No GUI needed. I run under CYGWIN unix environment on Win10 64b.
