8 years agoFPGA code is blocked
Hi, When I run my code in emulator mode, the result is right. But after compile and run it in FPGA, it blocked! My code have used a lot of channels. What's the problem? How to debug ...
8 years agoPlease, provide a better question. Saying "my FPGA wont work, what is wrong" does not help us to help you.
What are you doing? Can you post some code? are you simulating? can you post the test bench?
