11 years agoFound pins functioning as undefined clock
Hi, I'm encountering the following "Warning: Found pins functioning as undefined clocks and/or memory enables". I've gone into the "Classic Timing Analysis Settings", set an individual clock ...
11 years agoWithout seeing your code or .qar archive, this one sounds like you are using a signal IO pin as a clock input. The FPGA clock pins give you low skew and latency and should be preferred. You can use signal pins that connect to register or memory clock pins but the latency (delay from pin to clock pin inside chip) is much higher and sometimes timing wont work.
