Hi Chris,
Could you attach a simplified design that shows the error?
@JonWay_C_Intel I have created and attached two configurations of a example project configured to run on the Intel Cyclone 10 LP Evaluation Kit.
one configuration showing the error message, and one showing that the settings rejected by quartus are valid (using on the fly reconfiguration to allow compliation with lower clock speed).
The example contains a description on how it is constructed and how to connect it as well as the resulting output waveforms.
Materials required:
EK-10CL025U256
Oscilloscope with >= 1Ghz bandwith & differential probe, 100 Ohm LVDS termination resistor, + 1 Single ended probe
Quartus Prime 20.1.0 Build 771 06/05/2020 SJ Lite Edition
Thank you for your support,
Chris
