13 years ago
Force a reg not to use M9K but logic
Hi
I do use M9K for ROM tables and this works fine
I also have to use quite some latches since I works as pipeline
The problem are when I do use latches then QuartusII on some of the latches do use M9K and other a logic , then I do not have enough M9K for ROM
I have tried different combination with ramstyle="logic" in my verilog
(* ramstyle = "logic" *) reg [63:0] Block_out;
reg [63:0] Block_out /* synthesis ramstyle = "logic" */;
And still some of my reg do use M9K
Any hint?
    That did the trick
    Assignments -> settings -> analysis and synthesis settings -> more settings
    "auto shift register placements". Change this to "off".
    Thank you
    A global assignment works too, of course. As in the linked thread, the assignment is often required for specific objects.
