for loop in sdc file
is it possible to use for loops in the sdc file to help add constraints for multiple interfaces of the same type.
For example, I have 4 ata intefaces and so it would be easier if I could have a for loop setting the contraints the same for each. I have tried the code below which doesn't work, I get the error "Warning: Ignored filter at squid.sdc(115): ATA$x_DD [*] could not be matched with a port" and "Warning: Ignored filter at squid.sdc(115): ATA$x_IORDY could not be matched with a clock".for {set x 0} {$x<4} {incr x} {
set_input_delay -max 2.3 }] -clock
}Thanks in advance, Richard6 Replies
Thanks for the help, I couldn't get the first method to work but the second one does with some slight changes. I ended up with
Thanks again, Richardset data_in "ATA" append data_in $x append data_in "_DD"- BKevi
I think you can put all varibles that you want to concatenate behind the append.
for {set x 0} {$x<24} {incr x} {
set data_in {}
set dataout_h {}
set DFFLO {}append data_in {HDMI_RX_DAT[} $x {]}
append dataout_h {ddio_rx_24b:\ddio_rx_gen:ddio_rx_24b_inst|altddio_in:ALTDDIO_IN_component|ddio_in_87i:auto_generated|dataout_h[} $x {]}
append DFFLO {ddio_rx_24b:\ddio_rx_gen:ddio_rx_24b_inst|altddio_in:ALTDDIO_IN_component|ddio_in_87i:auto_generated|ddio_ina[} $x {]~DFFLO}eval {set_multicycle_path -from $data_in -to $dataout_h -setup } $l2h_setup_ref
eval {set_multicycle_path -from $data_in -to $DFFLO -setup } $l2l_setup_ref
eval {set_multicycle_path -from $data_in -to $dataout_h -hold } $l2h_hold_ref
eval {set_multicycle_path -from $data_in -to $DFFLO -hold } $l2l_hold_ref}
- sstrell
This is an 11 year old post. Perhaps you wanted to create a new one?
SDC is just tcl with a different extension so yes, you can use loops. But they need to be correct tcl syntax.
In your code, tcl has no way to tell that you want to replace $x instead of $x_DD. I don't have access to Quartus to try but I believe you need to use ${x}_DD. If that does not work, simply use string manipulation to build the signal name before using it: Set signal "ATA" String append $signal $x String append "_DD" Or something like that. Hope this helps DK - Altera_Forum
This link (http://www.tcl.tk/man/tcl8.5/tutorial/tcl4.html) may help.
