15 years agofor loop in sdc file
is it possible to use for loops in the sdc file to help add constraints for multiple interfaces of the same type. For example, I have 4 ata intefaces and so it would be easier if I could have a fo...
15 years agoSDC is just tcl with a different extension so yes, you can use loops. But they need to be correct tcl syntax.
In your code, tcl has no way to tell that you want to replace $x instead of $x_DD. I don't have access to Quartus to try but I believe you need to use ${x}_DD. If that does not work, simply use string manipulation to build the signal name before using it: Set signal "ATA" String append $signal $x String append "_DD" Or something like that. Hope this helps DK
