I need to match up the BAR size with the slave size the BAR master is working. I suspect the Cyclone Hard IP just doesn't support it or else the Component that I'm working with was compiled by IP compile not to support these offsets ... ( Did I get the terminology right ) ... I may need to attend IP compiler school as I don't know where to start with it.
Best Regards, Bob. - Altera_Forum
The attachment depicts the PCIe -> Avalon MM translation ... I see the offset values as input to the PCIe RTL but when I set them to non-zero values , a checker flags an error during synthesis ..
How do I take advantage of the offset values to make the BAR the same size as the slave IP the BAR master is connected to ? Thanks, Bob.
