9 years agoFloating Point multiplication problem!
Hello! I'm trying to mult 10-bit bus with floating point constant 0.5. To do this I am using a IP FP arithmetic blocks. First - conversion 10 bit bus to 32 float, then - multiplication block (3...
9 years ago --- Quote Start --- Thanks for help! On the other hand. I want to add a little offset to my NCO 10 bit sin signal. Sinus is represented by samples from 500 to -500. After adding 100 signed integer with adder from Altera IP (10 bits + 10 bits) at the DAC output I get a deformed sinus - the peak is inverted. Thanks in advance for any suggestion. --- Quote End --- Might be you are discarding MSB from result. You shouldn't. You get 11 bits sum then you either use bits(10:1) or (9:0) but this needs clipping(not recommended)
