9 years agoFloating Point multiplication problem!
Hello! I'm trying to mult 10-bit bus with floating point constant 0.5. To do this I am using a IP FP arithmetic blocks. First - conversion 10 bit bus to 32 float, then - multiplication block (3...
9 years agoHave you considered fixed point? the arithmatic is far simpler (it is just integer based mathematics) so the latency and resource requirements are much lower.
