9 years agoFloating Point multiplication problem!
Hello! I'm trying to mult 10-bit bus with floating point constant 0.5. To do this I am using a IP FP arithmetic blocks. First - conversion 10 bit bus to 32 float, then - multiplication block (3...
9 years agoI want to be able to multiply not only by 0.5, also for example by 0.2, 0.6, 1.2, 1.5. When i click on the LPM_constant I can change the data format to float. Is this wrong?
