9 years agoFloating Point multiplication problem!
Hello! I'm trying to mult 10-bit bus with floating point constant 0.5. To do this I am using a IP FP arithmetic blocks. First - conversion 10 bit bus to 32 float, then - multiplication block (3...
9 years agoMultiplying by 0.5 is the same as divide by 2, which is just a 1 bit shift to the right, and discard the LSB (and/or maybe do some rounding).
Why do you want to use floating point? LPM_Constant just drives an integer, not a floating point.
