14 years agoFixed point is simply just binary. Imagine the number 9.25
In 6 bit fixed point:b 1001.01 This is the same as 37: 100101 The only difference is a decimal place. So with fixed point arithmatic the decimal point (should probably be called the integer/fraction divider!) is just imaginary, so you would treat the fixed point number as if it was 37. The following rules apply: An M.N number + X.Y results in a max(M, X)+1.min(N, Y) number. M.N * X.Y = M+X.N+Y (Where M,N,X,Y are the number of bits). Have a look at the VHDL fixed point package: www.vhdl.org/fphdl Its the 2008 fixed point package in 93 format so you can use it with any synthesisor.
