14 years agoThank you kaz for your explanation. Now I understand what consideration to make when deciding the output latency. but the problem is we cannot have the latency of the megafunction as "our own will". For example the output latency for megafunction ALTFP_DIV are only 6, 14, 33. How if we want 50 output latency? All this time I always generate a slower clock to match the output latency or the timing diagram between each component.
What do you think kaz? Thanks in advance kaz. Thank you Tricky. Actually I thought of using fixed point but I cannot find any megafunction for fixed point (at arithmetic part). What I found is anything with ALTFP initial which is for floating point. Please correct me if I'm wrong. Is there any megafunction for fixed point? Thanks in advance Tricky.
