16 years agoFixed Point Multiplication in Verilog or Quartus II
Hello, I plan to implement a controller digitally in my FPGA & it involves numerous fixed-point additions, multiplications & divisions. Therefore here is a generic question: Suppose ...
16 years ago@amilcar : Thanks. The slicing idea seems nice !
@ FvM : Don't quite understand the problem you've suggested. Right now, what I've done is the following: As far as multiplication of fixed-point fractions is concerned, I've changed the product of fixed-point numbers A*B into the form: a*b = k*l*(m/n) where k & l = unknown integers; m & n are known integers. (I've also chosen M & N such that N is a power of 2 (n = 2^p) , to replace the 'division-by-n' with 'p-lsbs cutoff' - since this will save time). So now, I'm only concerned about integer multiplication. For that I'm using the 'lpm_mult' megafunction in Quartus II. It generates (by default) a 32-bit result for two 16-bit signed input multiplicands. I store this result in mult_32out. Now, i'm assuming that this "lpm_mult" computes its sign-bit correctly (i.e. deals with whatever problem you have specified). So, then - I just take the mult_32out[31]-bit as the correct result sign bit, and proceed. In the end, I have my required 16-bit result as: result_axb = {mult_32out[31], mult_32out[p + 14 : p]}; Its simulation yields correct results, so my assumption seems to be correct. What say ?
