corestar
Contributor
9 months agoFitter stalls on "Advanced Physical Optimization" on Windows 10
We are reluctantly moving from Windows 7 to Windows 10. I have a project that compiles just fine on a Windows 7 Pro machine with an Intel Core i7-3930K CPU using Quartus 19.1 Lite. I copied the proj...
- 8 months ago
AMD Ryzen support Simultaneous Multithreading (SMT) if check this https://www.techpowerup.com/cpu-specs/ryzen-threadripper-pro-3995wx.c2314 Could you try to turn off through BIOS?
corestar
Contributor
9 months agoI had another engineer try to compile this on his machine. It is the exact same version of Windows 10 Pro (10.0.19045 Build 19045), but has an AMD Ryzen 7 5800X 8-Core CPU. It compiles fine on his computer with Physical Optimization enabled and parallel compilation set to all available processors.
So it does not appear to be a Windows 10 problem. Apparently, Quartus cannot handle a processor with more than a certain number of cores.
