Fitter stalls on "Advanced Physical Optimization" on Windows 10
- 8 months ago
AMD Ryzen support Simultaneous Multithreading (SMT) if check this https://www.techpowerup.com/cpu-specs/ryzen-threadripper-pro-3995wx.c2314 Could you try to turn off through BIOS?
I did find this link that is oddly similar, but it was for Quartus 16.1 and the fix did not work. And no mention of it only happening on certain versions of Windows.
Why does the Quartus Prime software hang at "The Fitter is using Advanced Physical Optimization"?
- ShengN_altera9 months ago
I had checked the previous internal message based on the KDB link. This is not a bug but configuration problem so wouldn't be fixed. Please follow the workaround stated in the KDB
- corestar9 months ago
Contributor
I'm afraid, as I mentioned, I already tried limiting the number of processors and it does not work.
I'm sure alot of people use Quartus on Windows 10 Pro, but perhaps not so many have a 64 core processor. I assume it must have something to do with that. But it seems to me if Quartus cannot handle more than a certain number of processors, it should automatically limit itself as opposed to requiring the user to do so.
Possible provide the design file for debugging? can send to my personal mail
