kanthi
7 years agoFitter routing can't fit into device when we look the resource utilization is less than 60%. we are using stratix V device. how to fix this.
Error (11802): Can't fit design in device. Modify your design to reduce resources, or choose a larger device. The Altera Knowledge Database contains many articles with specific details on how to reso...
KennyT_altera
6 years agoJust to remind you to check your inbox again.
kanthi
6 years agoHi KTan,
Thanks you very much for your great support.
For our application, two parallel path one is MDI and other one is OOI. current we are Enabled only MDI path. (disabled OOI).
if we enable OOI path then we facing this fitting issue.
Time being we are focus only on MDI path.so, we can close this issue for while.
i will rise the ticket again once we are completed the MDI path and back to OOI.
once again thanks for your Great support and Tracking
Great KTan,
with best regards
sivakumar
