XG_Kang
7 years agoFitter Error
I have a design using 10AX057N4F40E3SG compiled with Quartus Prime Standard 17.1,If I don't change anything just do several compiles, some of the compile results work correctly,som of the compile res...
XG_Kang
6 years agoThis problem is solved with some special method. This case can be close. Thanks.
