XG_Kang
7 years agoFitter Error
I have a design using 10AX057N4F40E3SG compiled with Quartus Prime Standard 17.1,If I don't change anything just do several compiles, some of the compile results work correctly,som of the compile res...
XG_Kang
7 years agowe are doing some tests, please wait for result. It maybe need a little bit of time. Does Intel have any suggestions? By now , we found that same clock gives to read port and write port, problem would still happen. A backup ram with same reads and writes, data would change too. Same writes to a backup ram and different reading operations with repect to the original ram to read port, data could be fine. It is very strange.
