fitter error in Quartus Prime Pro 25.1.0.
You're confusing AS_DATA0 (for active serial configuration) and DATA0 used as part of the 32-bit bus for the FPP configuration scheme. Check what configuration scheme you have selected in the Device and Pin options (Assigments menu -> Device).
You don't mention if this is a commercially available dev kit (if so, which one?) or your own design. Details on configuration schemes are here: https://www.intel.com/content/www/us/en/docs/programmable/683775/current/configuration-design-security-and-remote-29047.html
- Hidetaka1 year ago
Hello, sstrell-san.
I don't think you've correctly understood my inquiry.
I'm assigning a signal to Pin_AE5. I'm getting a message saying that the Quartus Fitter cannot assign that pin to "~ALTERA_DATA0~". However, "~ALTERA_DATA0~" for this device should be Pin_Y4. The fitter pin is clearly wrong. There is an error in the device data used by the fitter.I think the problem is on the Quartus fitter side.
Incidentally, the configuration scheme is AS mode.Regards, Hidetaka,
