9 years agoFitter can't place 1 fractional PLL
Hi, we have a Cyclone V SX design that fails to compile because the fitter can't place 1 fractional PLL. I have compiled the design succesfully previously, but after I added two 2-lane HiSPi...
9 years ago --- Quote Start --- Hi Joonas, maybe you use just one LVDS_RX block with two channels or the "Use External PLL" option to share one PLL between the LVDS_RXs and other clocks. regards Jens --- Quote End --- I guess that we cannot share the PLL between the LVDS-inputs since the the LVDS-clocks come from two seperate image sensors that aren't syncronized between each other. Actually we have four image sensors so we would need four different PLLs and four different LVDS_RX-blocks. I'm not sure if this is possible with Cyclone V-device.
