12 years ago
First VHDL try
Hi to all
I'm trying my first VHDL code to replace a GAL
Quartus tells me :
Warning (10325): VHDL Choice warning at gal.vhd(30): ignored choice containing meta-value ""01XXXXXXXX00XXXX""
Warning (10325): VHDL Choice warning at gal.vhd(31): ignored choice containing meta-value ""01111111XX10XXXX""
Warning (10325): VHDL Choice warning at gal.vhd(32): ignored choice containing meta-value ""010XXXXXXX10XXXX""
Warning (10325): VHDL Choice warning at gal.vhd(33): ignored choice containing meta-value ""0110XXXXXX10XXXX""
Warning (10325): VHDL Choice warning at gal.vhd(34): ignored choice containing meta-value ""01110XXXXX10XXXX""
Warning (10325): VHDL Choice warning at gal.vhd(35): ignored choice containing meta-value ""011110XXXX10XXXX""
Warning (10325): VHDL Choice warning at gal.vhd(36): ignored choice containing meta-value ""0111110X0X10XXX0""
Warning (10325): VHDL Choice warning at gal.vhd(37): ignored choice containing meta-value ""0111110X0X10XXX1""
Warning (10325): VHDL Choice warning at gal.vhd(38): ignored choice containing meta-value ""0111110XX010XXX0""
Warning (10325): VHDL Choice warning at gal.vhd(39): ignored choice containing meta-value ""0111110X1X10XXX1""
Warning (10325): VHDL Choice warning at gal.vhd(40): ignored choice containing meta-value ""0111110XX010XXX1""
Warning (10325): VHDL Choice warning at gal.vhd(41): ignored choice containing meta-value ""011111100X10XXXX""
Warning (10325): VHDL Choice warning at gal.vhd(42): ignored choice containing meta-value ""011111101X10XXXX""
Warning (10325): VHDL Choice warning at gal.vhd(43): ignored choice containing meta-value ""01111110X010XXXX""
Warning (10873): Using initial value X (don't care) for net "dq" at gal.vhd(15)
This is my code :
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_unsigned.ALL;
ENTITY GAL IS
PORT (
a : IN std_logic_vector(15 downto 0);
dq : OUT std_logic_vector(8 downto 1)
END GAL;
ARCHITECTURE bus_decode OF GAL IS
BEGIN
PROCESS(a(15 downto 0))
BEGIN
CASE a(15 downto 0) IS
when "0100000110X00100" => dq(8 downto 1) <= "10111111";
when "01XXXXXXXX00XXXX" => dq(8 downto 1) <= "01111111";
when "01111111XX10XXXX" => dq(8 downto 1) <= "01111111";
when "010XXXXXXX10XXXX" => dq(8 downto 1) <= "01111111";
when "0110XXXXXX10XXXX" => dq(8 downto 1) <= "01111111";
when "01110XXXXX10XXXX" => dq(8 downto 1) <= "01111111";
when "011110XXXX10XXXX" => dq(8 downto 1) <= "01111111";
when "0111110X0X10XXX0" => dq(8 downto 1) <= "11011001";
when "0111110X0X10XXX1" => dq(8 downto 1) <= "11110111";
when "0111110XX010XXX0" => dq(8 downto 1) <= "11011111";
when "0111110X1X10XXX1" => dq(8 downto 1) <= "11101111";
when "0111110XX010XXX1" => dq(8 downto 1) <= "11101110";
when "011111100X10XXXX" => dq(8 downto 1) <= "11111001";
when "011111101X10XXXX" => dq(8 downto 1) <= "11001111";
when "01111110X010XXXX" => dq(8 downto 1) <= "11001110";
END CASE;
END PROCESS;
Can anyone help please ?
    --- Quote Start ---
    Hi fabf.
    The don't care '-' and 'X' are non synthesizable metavalues so don't use it.
    --- Quote End ---
    But you can use '-' in the std_match function to act as dont cares. (and I have successfully several times). I have seen it used as state machine decode where an engineer matched the outputs into the state values, it was kind of neat.
    @fabf
    My appologies, std_match is in the numeric_std package
