So as long as I split them up and do the blocking assignment int intermediate variable seperate it should function.
always @ (posedge sysclk)
begin
//do averaging
IEint = 32'h00000000;
IPint = 32'h00000000;
ILint = 32'h00000000;
QEint = 32'h00000000;
QPint = 32'h00000000;
QLint = 32'h00000000;
for(n=0; n<N; n= n+1)
begin
IEint = IEint + Iearly;
IPint = IPint + Iprompt;
ILint = ILint + Ilate;
QEint = QEint + Qearly;
QPint = QPint + Qprompt;
QLint = QLint + Qlate;
end
end
begin
IEtotal <= IEint / N;
IPtotal <= IPint / N;
ILtotal <= ILint / N;
QEtotal <= QEint / N;
QPtotal <= QPint / N;
QLtotal <= QLint / N;
//calculate control
My next question would be on an NCO. This is based on a simple sawtooth example I found for fixed freq output. If I feed the output to a sin and cos LUT I should be able to get my mixer values to quadrature split and remove carrier drift from the PRN. Does this code look correct?
module NCOcarrier(sampleclk, NCOout, control);
input sampleclk;
input control; //how to apply control? + or - to IF
output NCOout; //control 00 stay, 01 increase, 11 decrease chip rate
reg signalOut = 32'd0;
integer IF = 12000000; //set to center IF
always @ (posedge sampleclk)
begin
if(control == 2'b01)
begin
rate = rate + 1; //how much to advance or retard
end
if(control == 2'b11)
begin
rate = rate - 1;
end
end
begin
signalOut <= signalOut + IF * 64'h100000000 / 50000000;
end
assign NCOout = signalOut; //use signalOut as input value for LUT sin and cos
endmodule
How would I handle roll over of the 32 bit signalOut value? Seems like the value should be kept within 0-90degrees or equivelent to, so as to keep the LUT as small as possible. I'm going to have to think on that one a while.
