I appreciate your responses
I'm trying to keep it on a logic circuit flow. I'v split some of the functions down into seperate modules. Hopefully I can keep it better organized. It is fully compiling as it is with only a few errors. Pins incomplete IO assignments, I have not run through the pin placement yet. No clocks in design, i still have to figure out how to go about setting those up. Verilog HDL assignment warning at Basestation1.v(75): truncated value with size 4096 to match size of target (4095). I am not certain where I've got it wrong with that one. Those warnings apply to all of my shift registers.
module Correlator_Time_Domain_CA (sampleClock, DIFin, sinLUT, cosLUT, chipIN, IEout, IPout, ILout, QEout, QPout, QLout);
input sampleClock; //4.096Mhz
input DIFin, sinLUT, cosLUT;
input chipIN;
output IEout, IPout, ILout, QEout, QPout, QLout;
reg chip;
reg result;
always @ (posedge sampleClock)
begin
chip <= {chip, chipIN}; //shift in new early chip to lsb
result <= DIFin ^ sinLUT ^ chip;
result <= DIFin ^ cosLUT ^ chip;
end
assign ILout = result;
assign IPout = result;
assign IEout = result;
assign QLout = result;
assign QPout = result;
assign QEout = result;
endmodule
Then this is the next step, an adder module
module code_ADDER# (parameter N = 4096)(IL, IP, IE, QE, QP, QL, sysclk, codeNCOctl, phaseNCOctl);
input sysclk; //50Mhz
input IL, IP, IE, QL, QP, QE;
output codeNCOctl;
output phaseNCOctl;
integer n;
reg Iearly;
reg Iprompt;
reg Ilate;
reg Qearly;
reg Qprompt;
reg Qlate;
reg IEtotal, IPtotal, ILtotal, QEtotal, QPtotal, QLtotal;
reg codeAdvance;
reg phaseAdvance;
always @ (posedge sysclk)
begin
Iearly <= {Iearly, IE};
Iprompt <= {Iprompt, IP};
Ilate <= {Ilate, IL};
Qearly <= {Qearly, QE};
Qprompt <= {Qprompt, QP};
Qlate <= {Qlate, QL};
//do averaging
IEtotal <= 32'b00000000000000000000000000000000;
IPtotal <= 32'b00000000000000000000000000000000;
ILtotal <= 32'b00000000000000000000000000000000;
QEtotal <= 32'b00000000000000000000000000000000;
QPtotal <= 32'b00000000000000000000000000000000;
QLtotal <= 32'b00000000000000000000000000000000;
for(n=0; n<4096; n= n+1)
begin
IEtotal <= IEtotal + Iearly;
IPtotal <= IPtotal + Iprompt;
ILtotal <= ILtotal + Ilate;
QEtotal <= QEtotal + Qearly;
QPtotal <= QPtotal + Qprompt;
QLtotal <= QLtotal + Qlate;
end
IPtotal <= IPtotal / N;
QEtotal <= QEtotal / N;
QPtotal <= QPtotal / N;
QLtotal <= QLtotal / N;
//calculate control
if(IEtotal/N > ILtotal/N)
begin
codeAdvance <= 2'b11;
end
else if(IEtotal/N < ILtotal/N)
begin
codeAdvance <= 2'b01;
end
else
begin
codeAdvance <= 2'b00;
end
if(QEtotal * QLtotal > 1)
begin
phaseAdvance <= 2'b11; //control bits to advance or retard NCO module
end
else if (QEtotal < 1)
begin
phaseAdvance <= 2'b01;
end
else
begin
phaseAdvance <= 2'b00;
end
end
assign codeNCOctl = codeAdvance;
assign phaseNCOctl = phaseAdvance;
endmodule
I'm wondering about the adder function. Is there a good model to follow in syncronizing one module to the next when one does accumulate and averaging operations?
