I see the logic error in the for loops changed to
//sum shift register values
sumIe = srIe;
sumIp = srIp;
sumIl = srIl;
sumQe = srQe;
sumQp = srQp;
sumQl = srQl;
for(p = 1; p < SRsize; p = p+1)
begin
sumIe = sumIe + srIe;
sumIp = sumIp + srIp;
sumIl = sumIl + srIl;
sumQe = sumQe + srQe;
sumQp = sumQp + srQp;
sumQl = sumQl + srQl;
end
When I try a compile in Quartus2 vers 13.1 I get this current build errors
--- Quote Start ---
Info (12021): Found 3 design units, including 3 entities, in source file basestation1.v
Info (12023): Found entity 1: search
Info (12023): Found entity 2: Correlator_Time_Domain
Info (12023): Found entity 3: NCO
Info (12021): Found 1 design units, including 1 entities, in source file basestation.bdf
Info (12023): Found entity 1: Basestation
Info (12021): Found 1 design units, including 1 entities, in source file codegenerator.v
Info (12023): Found entity 1: CACODE
Warning (10236): Verilog HDL Implicit Net warning at Basestation1.v(118): created implicit net for "sine_lookup_output"
Error (12007): Top-level design entity "Basestation1" is undefined
Info (144001): Generated suppressed messages file C:/Altera/projects/output_files/Basestation1.map.smsg
Error: Quartus II 32-bit Analysis & Synthesis was unsuccessful. 1 error, 2 warnings
Error: Peak virtual memory: 345 megabytes
Error: Processing ended: Sun Apr 20 22:23:13 2014
Error: Elapsed time: 00:00:02
Error: Total CPU time (on all processors): 00:00:01
Error (293001): Quartus II Full Compilation was unsuccessful. 3 errors, 2 warnings
--- Quote End ---
Can I not run 2 operations in the same module? I know the calculation part will take more reference clock cycles than the signal input so I was trying to use "newData" essentially as a boolean value with the always block running at the reference clock checking to see "IF" it was set to 1 by the input block. Can I not work it that way?
I'm completely new to FPGA design.
