FIR II Decimation Frequency Response
Thanks for your help. As I run your latest fir_inspect.m in R2021a, it is passing. However, I come across different observation with yours. As shown in the following screenshot, the left one is I run with your original decim_fir2.zip + latest fir_inspect.m in R2021a only. If I fir_inspect.m in R2021a -> run Modelsim to get new decim_fir_output.txt -> rerun fir_inspect.m in R2021a, I get the right hand side plot. Not sure if I have missed out anything? Thank you.
- JordanD5 years ago
It appears the image is broken/blocked. Can you attach instead?
@CheePin_C_Intel Please try the new file attached. There may have been a problem with the file write. This updated script has been expanded to run the IP matlab model of the filter. I tested the entire workflow using R2021a.
