tsoundi
3 years agoFIR filter does not build but is implemented
Dear miss/mister,
I am an engineering student that just started to use Quartus prime in my internship. I am working on the bladeRF SDR(Software definded Radio) and I am implementing blocks to do s...
- 3 years ago
Please see the technology Map viewer as well. It seems there is no issue with the IP or build or resource estimation.
Can you please try with the simulation block by block and provide a sufficient input value to the filter, so that after multiplication with the coefficients it should not be very low value, at least you should get a signal in the +/-1 range. You definitely need to do scaling.
Thank you
Kshitij Goel
Kshitij_Intel
3 years agoHi,
What input you are feeding to the filter?
Can you please feed a constant sine wave @X Msps with the amplitude of +/-1.
Please let me know the result.
Thank you
Kshitij Goel
