13 years agoYou use FDA tool to generate the filter coefficients by setting the cut offs and all and then load these coefficients in the FIR compiler along with the entering the info related to the input and coefficients' bit widths and clock and data rate. Then you can generate your filter. Do the highpass/lowpass selection in FDA tool.
