VFlav
3 years agoFinal postfit netlist check failed ; Internal Error: Sub-system: FDRGN
Hey, I open discussion to report Final postfit netlist check failed. Quartus compilation crash at the end of fitter process. Problem Details are available below for more information. As recommand...
- 3 years ago
Thanks for your help
Unfortunately, I'm not authorised to share my project.
To complete the compilation, I had to delete DDR4 communication with FPGA.
This issue can be solve from your side with this modification.
RichardT_altera
3 years agoSorry, I don't get it. What do you mean by "This issue can be solve from your side with this modification"?
If you are not able to share the project, then we can not do anything to help you debug the IE as each design is unique.
Richard Tan
- VFlav3 years ago
Because we can't solve this issue, I just mean that this error is not a stumbling point for me anymore.
I can't share my project, so, I understand your inability to help me with this problem.
Anyway, thanks for your replies,
