Final postfit netlist check failed ; Internal Error: Sub-system: FDRGN
- 3 years ago
Thanks for your help
Unfortunately, I'm not authorised to share my project.
To complete the compilation, I had to delete DDR4 communication with FPGA.
This issue can be solve from your side with this modification.
Thanks for your reply,
Unfortunately, I can't update my Quartus version because of project traceability.
I'm looking for a solution, and an other error raise :
--- Quote ---
Problem Details
Error:
*** Fatal Error: Access Violation at 0000025664B18940
Module: quartus_fit.exe
Stack Trace:
0x25664b1893f:
0x236d: PLACE_DB::~PLACE_DB + 0x5d (db_place_db)
0xc029: `dynamic atexit destructor for 'PLACE_DB::s_place_db'' + 0x19 (db_place_db)
0x142d5: _execute_onexit_table + 0x155 (ucrtbase)
0x141fa: _execute_onexit_table + 0x7a (ucrtbase)
0x141b3: _execute_onexit_table + 0x33 (ucrtbase)
0xa819: dllmain_crt_process_detach + 0x4d (db_place_db)
0xa90f: dllmain_dispatch + 0xbf (db_place_db)
0x19a1c: RtlActivateActivationContextUnsafeFast + 0x11c (ntdll)
0x5dceb: LdrShutdownProcess + 0x24b (ntdll)
0x5da7c: RtlExitUserProcess + 0xac (ntdll)
0x1e0aa: FatalExit + 0xa (KERNEL32)
0x205bb: exit + 0x1db (ucrtbase)
0x2045e: exit + 0x7e (ucrtbase)
0x508c: err_ie_abort_or_exit + 0x3c (CCL_ERR)
0x45e08: MSG_ERROR_INFO::finalize + 0x248 (CCL_MSG)
0x46879: MSG_INTERNAL_ERROR::report_impl + 0x109 (CCL_MSG)
0x466ed: MSG_INTERNAL_ERROR::report + 0xd (CCL_MSG)
0x47394: `anonymous namespace'::fdrgn_final_check + 0x184 (fitter_fdrgn)
0x40a23: FDRGN_EXPERT::check_and_report + 0x2f3 (fitter_fdrgn)
0x13109: fit2_write_fitter_report + 0x169 (comp_fit2)
0x16442: TclNRRunCallbacks + 0x62 (tcl86)
0x17c4d: TclEvalEx + 0x9ed (tcl86)
0xa6a8b: Tcl_FSEvalFileEx + 0x22b (tcl86)
0xa5136: Tcl_EvalFile + 0x36 (tcl86)
0x1531c: qexe_evaluate_tcl_script + 0x3bc (comp_qexe)
0x14342: qexe_do_tcl + 0x4b2 (comp_qexe)
0x1a84e: qexe_run_tcl_option + 0x5ee (comp_qexe)
0x18ae1: QCU::DETAIL::intialise_qhd_and_run_qexe + 0xa1 (comp_qcu)
0x2a74c: qcu_run_tcl_option + 0x2ec (comp_qcu)
0x1a156: qexe_run + 0x446 (comp_qexe)
0x1b28a: qexe_standard_main + 0x26a (comp_qexe)
0x2052: qfit2_main + 0x82 (quartus_fit)
0x149b8: msg_main_thread + 0x18 (CCL_MSG)
0x16061: msg_thread_wrapper + 0x71 (CCL_MSG)
0x20d90: mem_thread_wrapper + 0x70 (ccl_mem)
0x13f3d: msg_exe_main + 0x20d (CCL_MSG)
0x2918: __scrt_common_main_seh + 0x11c (quartus_fit)
0x17033: BaseThreadInitThunk + 0x13 (KERNEL32)
0x526a0: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus_fit
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 19.4.0
Build: 64
Edition: Pro Edition
--- End quote ---
Maybe this give an other clue to fix this issue.
Thanks in advace for your help,
